Heated seats not working
'97 V6. At a loss as to why tried all the obvious any advice welcome. J3lly
Re: Heated seats not working
If you have check the switches, wiring, relays and fuses it could be the pads themselfs that have had it.
Oh and Hello and welcome:wave:
What relay's and fuses should I be looking at
are both seats not working or just one? most common problem is the wire breaks just at the seat back at the pivot point for the seat to tip forward.
list of fuses
knowledge/kb_show.php?id=15
list of fuses
Its both seats not working have checked fuses and relays all appear OK.
Switches illuminate when pressed.
Will check wiring for breaks as described.
Should both the seat and back heat up.
Regards Gary
Regards Gary
yes back and seat bit both heat up, would check that
A. the switch's are properly connected
B. the connector under the seats are connected
if they are get your self a test light and see if your getting power at the connector under seats
I had the same problem and its the heater pads that are broken
Phantom
have the same problem, never worked since i bought the car 3 mths ago but now getting a bit nippy so could do with heated seats. switches light up put no heat, so what should i check first? cheers
Ace_aka
Ace_aka wrote:have the same problem, never worked since i bought the car 3 mths ago but now getting a bit nippy so could do with heated seats. switches light up put no heat, so what should i check first? cheers
could try reading this post from the start
Check both connections under the seat if these are connected make sure you've got 12v at this point. If all ok then check the wiring as it passes next to the pivot points and is very prone to breaking, this happened on my passenger seat so I had to resolder the wires now all ok
cornishtaz
is it possible to replace the heating pads? has anyone done it? are the pads alone available for sale?
vaggelis00
i've checked the wiring and everything seems ok. but the seats are not heating. so propably the pads are off. where can i find new pads?
vaggelis00
Users browsing this forum: No registered users and 38 guests
