lower temp radiator thermostat fan switch
Re: lower temp radiator thermostat fan switch
by vaggelis00 » Fri Jul 10, 2009 8:06 am
viewtopic.php?f=16&t=40992
it didnt overheat so much before fitting the fmic.
i flushed the cooling system 2-3 months ago.
i havent replaced my thermostat. i think GEMA has what i need
vaggelis00
by James101 » Fri Jul 10, 2009 10:53 pm
so the fan wont kick in m8, try replacing the fan module seen it done the the garage on discovery turbo
If it's not broke, fix it until it is...........
by vaggelis00 » Sat Jul 11, 2009 12:57 pm
which is the fan module?
vaggelis00
by James101 » Sun Jul 12, 2009 3:57 pm
im not sure m8
by Callyman » Sun Jul 12, 2009 5:56 pm
James101 wrote:im not sure mate
Good advice :roll:
by James101 » Sun Jul 12, 2009 11:00 pm
James101 wrote:so the fan wont kick in mate, try replacing the fan module seen it done the the garage on discovery turbo
this was done on a VW golf like lol so im just thinking is it the same for all cars with A/C
by vaggelis00 » Mon Jul 13, 2009 8:38 am
i really have no idea about it. yesterday i removed the thermostat from the engine and i'll see how thing going now
vaggelis00
by steve08 » Mon Jul 13, 2009 9:10 pm
hi mate like i sed before u should fit a cool running thermostat and u havent sed if the oe intercooler is still in place
steve08
by moosebuster1st » Sun Jul 19, 2009 9:36 pm
It sounds to me like you may have a small overheat prob that came along at the same time as the fit of an FMIC, I have a/c and FMIC and no probs on stock thermostat, how hot is it where you are?
moosebuster1st
by vaggelis00 » Sun Jul 19, 2009 10:11 pm
i live in Greece and the summer is really hot. like 35-40 celsius. the prob is that the second scale of the fan starts at 120 degrees. i need to find a fan switch to start lower like 1 scale 95 degrees and second 105
vaggelis00
by vaggelis00 » Mon Jul 20, 2009 9:33 am
i think only gema motorsport had a switch like this but they dont sell it anymore :(
vaggelis00
by Callyman » Mon Jul 20, 2009 10:30 am
How is it running woithout the thermostat in?
If its ok, then the thermostat was shot and not opening fully. get a new STD one.
by vaggelis00 » Mon Jul 20, 2009 11:46 am
its the same with or without the thermostat, both ways the engine temperature is very very high
vaggelis00
by Callyman » Mon Jul 20, 2009 12:30 pm
If it's getting really hot without a thermostat then what good would a cool running stat make?
Sounds like you may have a huge air lock or semi blocked water ways. (if your lucky)
by vaggelis00 » Mon Jul 20, 2009 12:55 pm
i have no prob with the water pump like leaks or some noise. temp was checked through TECH1 and the temp gauge was ok. my headgasket was repaired at EDS in 2004 but i dont know what job was done.
callyman what do you mean by huge air lock?
vaggelis00
