**HELP** Both windows stuck down!!
by superfox233 » Wed Jul 15, 2009 2:34 pm
My windows havnt worked for a couple of months now, but as if by magic, they started going up and down this week.
BUT! I wound them down and now they are totally unresponsive to the buttons!! THEY WONT GO BACK UP!! (major security breach...)
Is there a way to manually wind them back up if i take the doorcards off??
PLEASE HELP!!
superfox233
Re: **HELP** Both windows stuck down!!
by Callyman » Wed Jul 15, 2009 2:58 pm
Checked the fuse?
by superfox233 » Wed Jul 15, 2009 3:23 pm
yup. and relays etc....
superfox233
by WillsToy » Wed Jul 15, 2009 3:25 pm
D o you have the overide button on center console???
just wondering if the windows are sensoring something in the way and stopping.
Will
WillsToy
by Stupink » Wed Jul 15, 2009 4:45 pm
not sure if its a seperate circuit or not, but you could try shutting hte windows with the key, ie hold the key at 45degrees anticlockwise for 30seconds.
by superfox233 » Wed Jul 15, 2009 5:36 pm
Took doorcards off and got the power probe in! Its appears to be the red wire (constant feed). As soon as i gave it a 12v feed from the probe, they worked!! Must have a brake in the wire behind the dash....
Does the central locking motor have a constant feed that i can 'share' with the window motor??
superfox233
by Callyman » Wed Jul 15, 2009 6:29 pm
I think the Cl is a constant feed and switched on the -ve side, but I wouldn't put that kind of load on what is prob a thinner wire for the CL
by Stupink » Wed Jul 15, 2009 6:34 pm
have you checked the door connectors? where they pass into the doors? the weather shield is poor and often when you remove the connector water pours out lol. give them a good clean up and dry up and try again.
by superfox233 » Wed Jul 15, 2009 8:21 pm
tried that. they seem fine.... :think:
superfox233
Users browsing this forum: Bing [Bot] and 9 guests
