Main Beam not Working need help
by Westy » Mon Jun 23, 2008 12:36 am
My main beam is not Working and I need help please. I need a circuit diagram to identify wires and pins to check the circuit can anyone help please?
Westy
Westy
by Fraz » Mon Jun 23, 2008 2:08 pm
Haynes book is your best bet, I presume you have checked the fuse and the actual switch??
by Westy » Mon Jun 30, 2008 3:40 pm
checked the fuse and replaced the switch (twice)
Could really do with some wiring info, ie pin numbers and colour codes for wires
Westy
V6 Wiring Diagram wanted
by Westy » Mon Jun 30, 2008 4:48 pm
Does anyone have a wiring diagram for a V6?
Westy
Westy
by Fraz » Mon Jun 30, 2008 5:58 pm
since the wiring is about the same on all calibras...a haynes book will help you out
if both main beams are out, the switch and fues are all ok...then would be looking at the relay ..which is in the frame behind the fuse box, cant say which one its K73 though
Wiring Diagrams
by Westy » Thu Jul 03, 2008 9:06 am
Does anyone have Wiring diagrams for a V6 Calibra? or know where they can be found?
My front lights have problems
Westy
Westy
by Fraz » Thu Jul 03, 2008 1:38 pm
already told him that...but seems he just keeps posting the same question all the time !!!!
Try a Haynes book, we are not allowed to publish the contents of the book if that is what your after ...its copyrighted
by Westy » Tue Jul 08, 2008 11:01 am
I don't have a Haynes manual and wondered if anyone had an elecronic diagram they could send me please.
Westy
by Westy » Fri Jul 11, 2008 1:16 pm
It's all mended thanks for your help.
Westy
by Joker » Fri Jul 11, 2008 4:34 pm
what an interesting post :roll:
Joker
