steering wheel
steering wheel
ebay item 160251383822
will this fit my cally what else (apart from the airbag) will i need and how hard would it be to fit
yip here is one in fraz car
http://www.clubcalibra.net/garage.php?m ... age_id=366
i have it in mine
aldo has it
stu has it
steva has it
i have it in mine
aldo has it
stu has it
steva has it
right you will need the squib, the wheel and also the plastic mount behind the wheel from a Vectra , the bit the indicator stalks clip into (you forgot about that bit Gordy) the squib wont fit the Calibra one
wheel on ebay like
http://cgi.ebay.co.uk/v-reg-vectra-sri- ... 247928145&
squib
http://cgi.ebay.co.uk/Vauxhall-Vectra-1 ... 286.c0.m14
wheel on ebay like
squib
You can get the relevant wiring adaptor & interface from Halfords, I fitted a Vectra 4 spoke Steering Wheel with Airbag & Stereo Remotes to mine, don't care what it says elsewhere, there is no need to modify or chop wiring behind the dashboard, it just needs one wire inserting into the car's original ISO Connector from the Vectra Wheel Controls. If you want to I can show you how to do it & save you a fortune on Auto Electrician's bills
JohnD
If anyone else out there is doing this mod & have Kenwood Head Units then go to here www.justkenwood.co.uk/remotes.asp then scroll to the bottom of the page & select Vauxhall Vectra & it takes you to the page with all the different adaptors/interfaces, & fascia panels etc, with all the prices.
JohnD
Users browsing this forum: No registered users and 80 guests
