Alternator fan prob
Alternator fan prob
Anybody on here know if the motor inside the V6 alternator fan is available...either that or any tips for a substitute? I investigated as when my lights and seats are on im only showing 12.5 volts
think my alternator could be up the chute now!
sam_p2000
Alternator should give a constant supply of about 14 volts no matter what the load or engine speed as they have a voltage stabaliser in them [img]/rolleyes.gif[/img] ...if mine is dropping down when its under load its obviously on its way out! All i need to know is how to fix or substitute the damn cooling fan motor so the new alternator wont die in the same fashon.
sam_p2000
True...im getting 13v with just the headlights on so perhaps things arent so bad....how important is that alternator cooling fan? It must have been siezed for a while as there are lots of old leaves in the fan housing. By that i mean should i stop using the car untill its fixed or will it be ok to use till one pops up on e-bay?
sam_p2000
I'd get it sorted as soon as poss...I know mine will come on for 10 -15 mins to cool the alternator (Just had a new one fitted after mine started to play up, however that was because it had been coated in oil from a leak for two years!)..not having it working will affect the life of the alternator I would immagine, and they ain't cheep. If it packs in you'll need a new alternator and a new fan?...better to be safe thatn sorry.
SE9
