ABS/Headlight problem !
With ignition off and turn the headlight switch on the dash lights up the same as when switching on ignition !
When i start the car engine running my headlights are flashing erratically !
I think the problem is something to do with my ABS because if i pull the fuse (which can get hot) Number 14 10amp the problems goes away !
Ive checked behind the fuse panel, engine bay and around the headlights and also checked behind the dash, i cant seem to find the problem ?
Anybody got any idea's ?
