Coolant Level Sensor Faulty
It must be..... now is it just a case of replacing the cap with the 2 connectors going into it????
Does anyone have one?
I've trauled round the breakers and hunted on the net to no avail!
hormonedmonkey
hormonedmonkey
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->I had a problem with mine,it was the pillar sensor inside,was very dirty and was not making a contact,took it out cleaned it up and was fine after that.<!--QuoteEnd--></div><!--QuoteEEnd-->
when it looked like i had to get yet another last year, i did this as well and it worked, when it stops working, i just wash it under a tap moving the float round, let it dry, then put it back in for another 6 months till it does it again
ROG
<!--QuoteBegin-ice man+--><div class='quotetop'>(ice man)</div><div class='quotemain'><!--QuoteEBegin-->If you take the connectors off the sensor does the light stay on?
If the float is down it makes the circuit, therefore unplugged the light should be off. if it's still on it's the wiring loom somewhere and not the switch.<!--QuoteEnd--></div><!--QuoteEEnd-->
<!--QuoteBegin-Naz+--><div class='quotetop'>(Naz)</div><div class='quotemain'><!--QuoteEBegin-->Take the connector off and short them out together. the light should go out then. If it doesn't, this means there is a break in the wire somewhere. But if it does go ut, then this means the cap is fautly. I think the cap from Vauxh is abou £30?!!!
Cheers<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry - conflicting advice and i'm probably wrong - i'm crap on electrical problems LOL
ice man
<!--QuoteBegin-ROG+--><div class='quotetop'>(ROG)</div><div class='quotemain'><!--QuoteEBegin-->when it looked like i had to get yet another last year, i did this as well and it worked, when it stops working, i just wash it under a tap moving the float round, let it dry, then put it back in for another 6 months till it does it again<!--QuoteEnd--></div><!--QuoteEEnd-->
It does work,i used a good limescale cleaner,think i used viakal or something like that,it really cleaned it up a lot.
Fostersice17
The way they work is that:
When coolant level is up to the right level, the float in the cap is floating so making a contact between the 2 pins, so the light stays out.
When the level falls below the level, then the float won't be floating anymore and won't make the contact, hence the light comes on.
This is how all the sensor wires are wired in the vauxhall. When they are ok( level ok) they make the circuit, and when the level is not ok, then they break the circuit.
Naz
