Switched Earth or Live?
Does anyone know if the door switchs controlling the interior light is a switched earth or live.
Thanks
Thanks
Twangy
Twangy
Ok for drivers door, but I need one for the passenger door aswell, but theres a sh*t load of wires running near the passenger door. Does the same wiring convention follow through the whole car? ie +12v red, Ground brown etc. I might just end up using the +12v from the head unit, it is half way between. I just dont like running too many wires near those heater control cables the alarm LED wires already obstruct one of them already.
Twangy
We Have The Power
<!--QuoteBegin-p_single+--><div class='quotetop'>(p_single)</div><div class='quotemain'><!--QuoteEBegin-->Ok for drivers door, but I need one for the passenger door aswell, but theres a sh*t load of wires running near the passenger door. Does the same wiring convention follow through the whole car? ie +12v red, Ground brown etc. I might just end up using the +12v from the head unit, it is half way between. I just dont like running too many wires near those heater control cables the alarm LED wires already obstruct one of them already.<!--QuoteEnd--></div><!--QuoteEEnd-->
Not sure what is for you never said but you will find a red 12+ coming out of passenger door loom along with quite a few more it will be thicker than the rest
Ian
Ian
MR_TOAD
