clocks
clocks
by projectcalibra » Fri May 19, 2006 8:38 am
how do i fit a digital clock in my calibra, it currently has the analogue 1, is there a plug behind the dash for it or do i need to cut the wires and join them to the digi clocks plug?
projectcalibra
by pas » Fri May 19, 2006 11:14 am
You need to cut wires...
Try search I know there was few discusions about that before, I think you will find all info you need...
pas
by ross85 » Fri May 19, 2006 11:27 am
:iagree: Put one in mine was quite easy. Just got three wires to connect up to the clock +ve, -ve and ilumination if I remember right, and then two wires for the temperature sender which normally sits under the front bumper. I had to drill a hole behind the glovebox for my alarm and amp so ran temp sender wiring through there.
ross85
by projectcalibra » Fri May 19, 2006 7:33 pm
does that mean i need to get a temp sensor too?
projectcalibra
by ross85 » Sun May 21, 2006 2:10 pm
Yep [img]/wink.gif[/img] Mine came with the temp sender, don't often see them for sale on their own. You could probably try autovaux or something as I can't see the sender being that expensive.
ross85
by projectcalibra » Sun May 21, 2006 4:55 pm
got a 2.0 GLSi cavi as a donar car, will just take it off that
projectcalibra
by projectcalibra » Mon May 22, 2006 7:18 pm
ok, think i have taken the sensor off the cavi, and the digi clock, and cut the plug for it, only thing is, it has more than 5 wires, wat cld the other 1s b 4?
projectcalibra
by ross85 » Mon May 22, 2006 8:16 pm
Lol don't know what the other wires were for - I tidied them up and taped them up and not had any problems for the year its been in. Think I had two spare?
ross85
by projectcalibra » Mon May 22, 2006 9:44 pm
yup 2, they were connected in my 2.0 glsi cavi, but in my 1.8 glsi cavi it only has 5 wires.
projectcalibra
by projectcalibra » Mon May 22, 2006 10:33 pm
which wire is which, i got the + and - ones, which are the other 3?
projectcalibra
