Little 'f' displayed on the fuel computer
by icewizard » Sat Apr 08, 2006 1:23 am
What does it mean, I've been told it's a fuse blown but I've checked mine and they are all ok.
Only appears sometimes though and only with the ignition off???
icewizard
by Leigh » Sat Apr 08, 2006 1:35 am
Only time I've seen that was when I had the chip out of the unit for a while waiting for it to be reprogrammed. I think you might also get it if the temperature probe is faulty/bad wiring.
Infact , just had a dig through my many dusty saved files on the PC, and managed to find one about the trip comp, here's a short clip [img]/smile.gif[/img]
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->A fault code will be stored if an F is displayed. These can be read out from the fuel computer.
Short pins A and D on the diag plug.
Switch on the ignition.
First 12 is flashed 3 times in the top display. Then if a fault code is stored it will be flashed 3 times. Otherwise - - - is flashed 3 times.
To clear the fault codes press the raised button.
167 Tank sensor voltage low, short circuit
168 Tank sensor voltage high, open circuit
169 Outside air temp sensor short circuit
171 Outside air temp sensor open circuit
173 Fault with fuel signal from ecu<!--QuoteEnd--></div><!--QuoteEEnd-->
Leigh
by akuma » Sat Apr 08, 2006 2:27 pm
i got an f also displayed on mine, but this was after i got an uprated fuel pump installed. plus my fuel level gauge aint working.
akuma
by joeraz » Sat Apr 08, 2006 10:41 pm
as far as i am aware, it means theres a fault code to be read
as in theres summit broke,, a sensor has picked up a loose connection or summit,,
works on almost everything, even a faulty outside temp gauge
joeraz
by icewizard » Sun Apr 09, 2006 10:10 pm
Thanks guys, I'll check it out when I get chance, just been busy replacing my rear brakes and their a real pain in the arse.
icewizard
by akuma » Mon Apr 17, 2006 2:13 pm
rear brakes? easier than the front to do. where is the wiring on the fuel tank. will i have to take the tank out to get to it? how easy is that to do?
cheers
akuma
by RobbieV » Mon Apr 17, 2006 2:31 pm
For a V6, but some useful info
<a href="http://www.v6calibra.com/docs/calibra_v6_fuel_computer.htm" target="_blank">http://www.v6calibra.com/docs/calibra_v6_fuel_computer.htm</a>
by Stig » Mon Apr 17, 2006 3:24 pm
akuma: drop the tank by its straps and you should see the wiring all there also remove the fuel pump etc as the sender unit for the gauge is integral to it, whoever fitted the fuel pump may not have plugged it in or even possibly didnt even fit it. may just be a faulty unit
Stig
by Stig » Mon Apr 17, 2006 3:28 pm
scrap that last post didnt read the date
Stig
by Sackie » Mon Apr 17, 2006 3:29 pm
It means that there is a Fault on your fuel computer, probably the Temp sensor as these always go mate, check through your computer either while driving or what ever and check your other readings also as it could be a fault with the consumption thingy. I had an F on mine for a while, now my outside temp guage tells me it is 54 degrees every day LOL
Sackie
by RobbieV » Mon Apr 17, 2006 3:31 pm
<!--QuoteBegin-Stig+--><div class='quotetop'>(Stig)</div><div class='quotemain'><!--QuoteEBegin-->scrap that last post didnt read the date<!--QuoteEnd--></div><!--QuoteEEnd-->
Whats wrong with the date ?
by Stig » Mon Apr 17, 2006 3:35 pm
im having a bad day!! was looking at the join date!!
Stig
by akuma » Tue Apr 18, 2006 4:19 pm
dropping the tank.... this is gonna be fun.
akuma
by ice » Fri Apr 28, 2006 5:59 pm
does the f come up if your have unplugged the reverse light switch?
ice
by RobbieV » Fri Apr 28, 2006 6:05 pm
<!--QuoteBegin-ice+--><div class='quotetop'>(ice)</div><div class='quotemain'><!--QuoteEBegin-->does the f come up if your have unplugged the reverse light switch?<!--QuoteEnd--></div><!--QuoteEEnd-->
The reverse light switch is not connected to the fuel comp.
