AI606 (although ineed the diagram for the standard alarm blo
As subject, im wiring this alarm into my car, now ive got all the instructions for the alarm, but i dont know which wire does what on the standard alarm block, can anyone help?
Cheater2k
This is a very rough guide, use a voltmeter to check if you can before you connect anything.
Black/Brown -------- Tailgate lock barral (grounded when pushed with key in I think).
Black/Blue ---------- Arms the alarm on when the drivers door is deadlocked
Brown/Red ---------- Horn, Siren (Grounds when Alarm sounding)
Brown/Black -------- Diagnostics Socket
Brown/Blue --------- Diagnostics Socket
Red ---------------- Perminant 12v
Black --------------- Ignition on 12v
Grey --------------- Grounded when passenger/Driver door open
Brown/Black -------- Boot Switch (Grounded when boot open)
Brown/White -------- Ground's through the heated rear screen (open circuit if window smashed)
White/Black ------- Left Indicator (12v)
White/Green ------ Right Indicator (12v)
Brown/Violet ------- Radio???
Brown/Green ------- Bonnet switch (Grounded when open)
Brown ------------- Perminant Gnd 0v
The multicore is to the ultrasonics and you won't need them.
In the door loom you will find a Brown/Black wire, if you connect this to the white wire on the toad then it can close the windows when arming.
icewizard
<!--QuoteBegin-Cheater2k+--><div class='quotetop'>(Cheater2k)</div><div class='quotemain'><!--QuoteEBegin-->cheers mate, ive got that manual, but its not just for the calibra, i need to know where to put the wires in the car (wiring into the existing alarm block which plugs into the silver unit)<!--QuoteEnd--></div><!--QuoteEEnd-->
Sorry about that, would help if i read the question
dont know much about the vauxhall alarm but i know someone in the trade will see if he knows any sites etc
Will
Will
WillsToy
Cheater2k
