New Clifford alarm fitted
Hi guys and gals,
as the title says, had clifford alarm fitted,
but the proximity sensor isnt doesnt go off when you are near the car,
any body know how to set it? or change the proximity on it?
Its a concept 650.
cheers...
Its a concept 650.
cheers...
VivSE5
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->you can buy the datalink cable/cd from them for about 15-25quid i think then you can just plug in your laptop and ajust everything whenver u like [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Not everything unless you have the installer version.
Admin
<!--QuoteBegin-VivSE5+--><div class='quotetop'>(VivSE5)</div><div class='quotemain'><!--QuoteEBegin-->So not the best choice of alarm then!!!!!!<!--QuoteEnd--></div><!--QuoteEEnd-->
It is a good choice of alarm, I will use a Clifford alarm every time that I get a chance.
I have had very few problems with any of the Clifford alarms i have had, and i have been using them for 10 years almost now.
Pop down to your local dealer they will probably do it for you while you wait, it literallt is only a 30 second change to make, just make sure that you take the master remote control with you.
Admin
I set mine up via the valet code and the remote, the options you need are not listed in the normal guide you get, I have a installer version somewhere that tells you how to adjust the range via the remote, its for a 600 but it will probably be the same.
Let us know if you need a copy.
Gary.
Gary.
LET the fun begin.
<!--QuoteBegin-Tattooman+--><div class='quotetop'>(Tattooman)</div><div class='quotemain'><!--QuoteEBegin-->i got a concept 400 and i can change the proximity sensor via the remote! surely this can be done with yours too,no?<!--QuoteEnd--></div><!--QuoteEEnd-->
It can be, you just need to ask the dealer nicely to tell you how to do it [img]/wink.gif[/img]
Admin
yea, its quite simple to do using the master remote, I have done it a few times but cant find the sequencing anywhere for mine, otherwise I would let you know. Don't make it too sensitive though, mine was forever going off at one point and the neighbours really wern't happy lol !
