Under bonnet light
Under bonnet light
by se6 » Sun Mar 27, 2005 11:14 am
This morning i removed the bonnet lining.
I knew that there was a light under the bonnet and knew that it didnt work.
Basically it isnt attached to anything. I can see that the brown wire is my earth and just needs screwing down. The other wire is a long black one which is long enough to reach into the engine bay. It has a spade connector on the end, only thing is i dont know where i need to connect it.
I assume that it needs to go to a pressure sensor of some sort, or it would be on all the time, am i right?
It must have worked at some point because the bulb has blown that was it in.
Can anyone help at all???
Thanks
by ROG » Sun Mar 27, 2005 11:50 am
It doesnt have a pressure sensor, it only lights when the lights are on, all the time even when the bonnet is down!, i cant remember exactly where to connect the wire ( not going outside now as its pi**ing down!), but it goes to the loom by the pollen/cabin filter ,by the wires to the interior fan. under the plastic bit at the back of the engine bay that goes to the window.
ROG
by BazV6er » Sun Mar 27, 2005 12:43 pm
mine wasnt working becuase a bulb had blown and id only realised the other day that i had a bonnet light that actually works.
by ecosseM » Sun Mar 27, 2005 12:53 pm
bonnet lights are on all the time, when you turn your lights on, this is why normaly the bulbs are blown.
the lights brown earth wire should be screwed into the bonnet with a 7mm speed bolt, hole should be near the location of the light.
the power/feed wire (black) feeds down inside the bonnet and comes out where you washer jet pipe feeds in, the connection for this(i think) is along by the heater blower. easeist way is just to check with test light to be safe, when you find an appropriate looking wire.
ecosseM
by se6 » Sun Mar 27, 2005 4:39 pm
Thanks for the replies guys, if it clears up today or tomorrow i shall go and have a look.
I knew you wouldnt let me down!
by Animal » Mon Mar 28, 2005 1:53 am
I still dont think I have one of these. I found something that looks like a blanking thing in the bonnet lining. Is this where its normaly found?
by ROG » Mon Mar 28, 2005 9:22 am
yeah it goes at the blanking plug, ive got the blanking thing with no light on my M turbo, but on the K 16v ive got a under bonnet light, the Kreg has headlight washers as well , turbo doesnt
ROG
by splinter » Mon Mar 28, 2005 1:10 pm
I didnt have one on mine but trying To fit one, but where do the wires go to. ?????
by ROG » Mon Mar 28, 2005 4:37 pm
Theres only one wire on mine, it earths through the bonnet
under the plastic bit where the fan motot is find the main wires to the fan, the bit of loom going there has a load ?4 thick wires going to the fan and one thin green wire with a spade connector on the end this feeds next to the washer tube and into the bonnet to the light., it must just connect to the headlight feed so if you havent got one just run a wire over to the lights.
wire is there only on the car with headlight washers K 16v
Deffo not there in loom on M turbo ( just had a look about fitting one onto mine )
ROG
by Animal » Mon Mar 28, 2005 5:25 pm
Suppose u could just put it on the side light feed, if the wires not there.
Is the holder similar ot the one in the glove box? The hole looks about the same size
by Tattooman » Mon Mar 28, 2005 9:40 pm
i can make a suggestion for an underbonnet light!
Tattooman
by Animal » Mon Mar 28, 2005 10:57 pm
lol would it involve lots of pretty leds? [img]/biggrin.gif[/img]
by Tattooman » Tue Mar 29, 2005 12:02 am
[img]/wink.gif[/img] yup
Tattooman
by ecosseM » Thu Mar 31, 2005 6:36 pm
no point in the GM/OPEL under bonnet light, it lights up s f a.
ecosseM
by ROG » Thu Mar 31, 2005 7:05 pm
true, total waste of time, but you could fit something from iceled in the same position ,to light the engine up with the bonnet open. leds would be better anyway because of the vibration and heat.
ROG
