Carlton/senitor digi dash pinout
Re: Carlton/senitor digi dash pinout
by superfox233 » Fri Oct 29, 2010 3:45 pm
GET ON IT TAZ!! 8)
superfox233
by welshwizard999 » Mon Nov 01, 2010 1:55 pm
Anyone got any info found some online but need more.
welshwizard999
by Fraz » Mon Nov 01, 2010 3:19 pm
welshwizard999 wrote:Anyone got any info found some online but need more.
more info to do what?? what have you found out so far as no point giving you the same information
and did you read this
Fraz wrote:if its the same as the Vectra one
Black large connector Pin 3 Ignition pin 13 ground
white connector Pin 5 Ignition and pin 15 Ignition 9 and 10 are ground and pin 24 is 12volt constant supply
blue connector is for check control so not really need to test
