steering out of control
Cut and dissconeted wires? what do they do?
by fromejason » Sun Jan 02, 2005 1:45 pm
hi you lot got a 20 16v red top on a 1993 L reg and me steering wheel wont take me in a straight line at all and i got a knoking as well it stops when i go aroung a bend but then there is a claking noise the tyrers are all pumped up fine dont no what to do can any one help ?
fromejason
by gran » Sun Jan 02, 2005 1:50 pm
check tracking, are the wheels balanced?
rod ends maybe??
then again a knocking noise could well be suspension related? check dampers and springs?
gran
RE: steering out of control
by fromejason » Sun Jan 02, 2005 1:54 pm
just got the thing some one sead it might be power steering or some thing
how do i find out what to look for ??? thanks
fromejason
by Fraz » Sun Jan 02, 2005 2:11 pm
jack the car up and grab the wheel at top and bottom ...give it a good shake and see if there is any movmnet
do same at the three and nine postion of the wheel
turn wheel from lock to lock and check for any play in rack
if your not sure, take it for an MOT and get them to check it out for you
RE: Cut and dissconeted wires? what do they do?
by fromejason » Sun Jan 02, 2005 2:27 pm
ok thank you
fromejason
