Jack hammer vibrations: Quick response!
by DC 12v » Fri Jul 25, 2008 2:07 pm
Ok Gang!
I've got the car up on miniramps, but it can't stay long as they're on loan.
I've mentioned on multiple forums a "jackhammer" feeling as I turn into corners. This is on both sides, the NS more than FS.
The ARB links are spot on. No problems, knocked them, shook them, pulled/pushed, no movement or sign of excessive wear.
The wheels are out of balance and the brake disks are warped, however I'm confident this isn't the cause, as this gives a shudder rather than jackhammer.
I've got a whole heap of things I can poke which I've found after crawling under there.. what would you suggest I look for?
I don't know if these will help, but I'll throw them in anyway
Thanks
Jay
DC 12v
by vinny_69 » Fri Jul 25, 2008 2:14 pm
how about abs rings?
vinny_69
by DC 12v » Fri Jul 25, 2008 2:15 pm
1) where do I find them
2) what do they look like
3) would they actually cause that?
DC 12v
by fraggie » Fri Jul 25, 2008 2:15 pm
try the wheel bearings, get the wheel off the ground and look for excessive play in a vertical manner (shake the top and bottom) if it moves or shakes it could be the wheel bearings. Should be looked for ASAP as a dodgy wheel bearing has been known to shear off and wheels go flying.
fraggie
Checking now Fraggie..
DC 12v
by DC 12v » Fri Jul 25, 2008 2:18 pm
No play in any wheel, though the fronts are slightly lower in inflation than I usually allow.
DC 12v
by vinny_69 » Fri Jul 25, 2008 2:21 pm
DC 12v wrote:1) where do I find them
when i slam on the brakes for emergency reasons and hit a slight bump the abs looses the plot and sounds fecking awfull.they are behind front discs look like a cog.check for damege i.e missing teeth
on second thoughts no they wouldn't cause that i will shut up :oops:
vinny_69
by tazz666 » Fri Jul 25, 2008 2:21 pm
front shokers, may be gone as i had this and the front shokers were gone so try that it may be them but i most probably wrong but you never know
tazz666
by DC 12v » Fri Jul 25, 2008 2:45 pm
Have replacement front shocks in the Barn. That could be ok to replace.
Diff bearing - where would I find that, and would it affect both sides on cornering?
CV joints, where are they? - You'd be suprised at how mechanically stupid I am - so maybe I missed it?
If any pictures are required, ask. AS I'm literally led under the car typing away lol
DC 12v
by DC 12v » Fri Jul 25, 2008 3:14 pm
Don't run off .. !! :)
DC 12v
by DC 12v » Fri Jul 25, 2008 5:36 pm
Is this what you mean?! There's movement indeed! (turn volume up for the clunks lol)
I work! ... sometimes! :D
DC 12v
by vinny_69 » Fri Jul 25, 2008 5:42 pm
is the other end connected to anything?
vinny_69
by vinny_69 » Fri Jul 25, 2008 5:45 pm
thanks for removing the pic DC ](*,)
vinny_69
by DC 12v » Fri Jul 25, 2008 5:54 pm
Deserved it's own topic! :D
DC 12v
by vinny_69 » Fri Jul 25, 2008 6:06 pm
:bang:
vinny_69
