Spot the problem!
Spot the problem!
OK, after many years of Calibra ownership you get to notice the small differences that are causing you grief..
Had a knocking noise start a couple of days ago on backing into the drive (slight kerb to go over, the lowered bits at drive entrances..), then today when accelerating/braking/speedbumps etc.
Only the trained eye will be able to spot the minor differences between the drivers and passenger sides that I saw tonight when I jacked her up after work..
Look closely now.....
Drivers side:
Passenger side:
Hmmm....can you tell the difference..!
Just as easy and cheap I guess to renew both wishbones?
Of course it would have to be passenger side, currently one of the locking bolts is stuck (wrecked 2 keys so far trying to remove it), another job for the helpful fitter at my work (he got one of the rear bolts out the other week even after the top had sheared off from me trying with a socket hammered onto it)
Drivers side:
Passenger side:
Leigh
Thanks for the offer mate, but I've just come back from the local motor factors , 2 wishbones, 2 ARB links for £48 (£18inc VAT for wishbone, £6 inc VAT for a ARB link), and they had them in stock.
(phoned another local factors first and they wanted £25 +VAT per wishbone, and £9 + VAT per link !! err I think not..
Picked up a bottle of Autogylm SRP while I was there as well so if I've time left over I'll give her a treat , LOL
Now just the small issue of getting the stupid f*cking locking bolt removed, then the fun and games of my first ever wishbone change.
Leigh
use a blowtorch on the bots that go into the body/subframe, it will make them a lot easier to undo, the problem is the captive nuts inside the subframe have a tendency to rust and snap off, this happened to me and it was a right pain to sort out....
I've just been out under the car after I got in from work and tried to squirt some penetrating oil and WD40 around/at/in the various bolts, in the vain hope it will ease the aggro come the time I actually attempt it,
nothings going to happen until mr-stuborn-big-locking-wheel-bolt comes out tho..
Leigh
Well I did the broken ARB yesterday, didn't have time to do drivers side, tho if it's as easy as the passengers I should get it done at the w/end. I'm afraid I chickened out of attempting the wishbones this time tho, they will have to be done another w/end (or by a proper mechanic , LOL )
Really was pleasantly suprised how easy the ARB was to do, even when the smaller bottom nut snapped when I was trying to undo it (of course).
Also replaced sunroof this weekend (yay, now I can have the headlining back in since it's been out from Aug 2008!), and the horn , so a fairly productive few days, happy I got that stuck wheel bolt out on my own as well...I think my seat subframe is the only thing that didn't go according to plan.
Leigh
leigh,
even i thought the wishbones were hard to change over but i did both sides on my 16v,as tazz said the real nightmare is the older pendulem arb links (i swore the queens name when i got mine on with a lube
cant wait to see how even easier they are to do on my v6 hehe ...
Cheers Baz, I still want to try them, just got a bit late in the day to be starting something I was a bit dubious about, and needed the car the next day for work.
Was really pleasantly suprised how easy the ARB was tho, hope the drivers side is a similarly painless experience when I change it. Sounds daft I know, but that one ARB link seems to have made a hell of a difference to the feel of the car, it must have been suffering a fair bit before it fairly gave up the ghost and sheared completely. Quite looking forward to when I've got the other one, plus wishbones, plus new track rod ends (passenger side bolts are seized/stuck on those..grrr)
Leigh
