Knocking and slight creaking at the front!!
Hi there guys,
Got a 16v redtop. Just had lowered shocks and springs fitted along with 2 new wishbones and cv joints. Just recently noticed i get a creaking sound then one knock occasionally when moving steering right and left and also when moving of slowly.
Any ides what this could be??
Seems to be coming from only the driver side under neath the car on near the alloy somewhere. The sound isnt there all the time is magically dissapears sometimes but its really annoying when it comes back.
amit710
funny you should say that mine does that when you steer of slowly i get a knocking noise
well just a knock i took it to the garage and they said my passenger steering rack ball joint is
damaged i yet to repair it look to see if yours is ok chance is when they lowered it they hit the bull joint with a mallett
and damaged the bull joint.
danstone
The shocks and springs are both brand new. One of the anti roll bar link was broken so got two of them replaced, but knocking is still there.
Could it has something to do with the drive shaft as its got a bit more pressure on it from lowering???
Track rod ends and ball joints have been checked and they are fine.
Its all still a puzzle for me.
amit710
ive had a annoying creaking noise over the last few mths , igot underneath the front of the car and rocked it backwards and forwards and found the noise was coming from the rear rubbers of the wishbone , so mr wd40 came in very handy and now theres no noise
I had the very same problem with my 20XE. Replaced the N/S wishbone and track rod end(tie rod end if you prefer) and it sorted the job. According to the Vauxhall TIS2000 software its a siezed track rod end, resulting in a slight knock when manuvering at low speeds or driving over differing terrain. Its worth replacing even if the originals seem in good order (as did mine), at under a tenner you can go wrong!
Jonesie
