Another brake question
by Animal » Mon Mar 06, 2006 7:24 pm
Got some discs today and they turned out to be wrong because they had the bearing bit inside. But the only others they say there is are 270mm. They are 4 stud but they say they are 4wd discs.
I have a 2.0 16v ecotec.
Any ideas?
by RobbieV » Mon Mar 06, 2006 7:28 pm
<!--QuoteBegin-Animal+--><div class='quotetop'>(Animal)</div><div class='quotemain'><!--QuoteEBegin-->Got some discs today and they turned out to be wrong because they had the bearing bit inside. But the only others they say there is are 270mm. They are 4 stud but they say they are 4wd discs.
Any ideas?<!--QuoteEnd--></div><!--QuoteEEnd-->
Bearing bit inside ? whats that then ?
by Animal » Mon Mar 06, 2006 7:32 pm
The disc wasn't hollow it had like a tube running down the centre that holds bearings.
Also where as the one that is is flat like this ]
The one I got had a lip on it, kind of like it would look like if it was on the car. Something like this }
by davefly76 » Mon Mar 06, 2006 10:05 pm
they've given you the early discs mate. the place i got mine from did the same thing funnily enough.
[img]/smile.gif[/img]
davefly76
by Animal » Mon Mar 06, 2006 10:27 pm
The ones they've ordered are 270mm will these not fit?
by nigw » Mon Mar 06, 2006 11:06 pm
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Calibra 2.0i 16v 90-98 rear
<!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Solid - Mountings 4
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Disc diameter 270.0mm
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Disc thickness 10.0mm
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Overall height 77.0mm
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Centre diameter 57.0mm
<!--fontc--></span><!--/fontc--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo-->Minimum thickness 8.0mm
<!--sizec--></span><!--/sizec--><!--fontc--></span><!--/fontc--><!--sizec--></span><!--/sizec--><!--sizec--></span><!--/sizec--><!--sizec--></span><!--/sizec--><!--sizec--></span><!--/sizec-->
nigw
by nigw » Mon Mar 06, 2006 11:10 pm
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Calibra 2.0i 16v Turbo 4x4 4/92-96
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->[/font]
[font=Arial]<!--fontc--></span><!--/fontc-->
<!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Solid - Mountings 5 *****
<!--fontc--></span><!--/fontc--><!--sizeo:-1--><span style="font-size:12pt;line-height:100%"><!--/sizeo--><!--fonto:Arial--><span style="font-family:Arial"><!--/fonto-->Centre diameter 65.5mm ******
nigw
by nigw » Mon Mar 06, 2006 11:15 pm
dsk535 is for the 8v 1st pic
dsk574 is for 16v
nigw
by turbo i wish » Mon Mar 06, 2006 11:52 pm
i had loads of problems like this on my cav gsi the rear discs they gave me were wrong. with the lips etc. i ended up taking the disc in for them to match it up and they said they were cav 4x4 discs.
turbo i wish
by nigw » Tue Mar 07, 2006 7:17 pm
obviously dont know what they are doing i checked all our listings at work today and its pretty hard to get it wrong.
:frown:
nigw
by Animal » Wed Mar 08, 2006 12:46 am
Done it today and for the record, your one was spot on! [img]/biggrin.gif[/img]
270mm
Users browsing this forum: Bing [Bot] and 19 guests
