Brake questions
by dj_smurph » Wed May 10, 2006 11:01 pm
soak them over night in wd40 or plusgas
if that dont work then blowtorch
or wack the bolts with a hammer see if the shock releases them
dj_smurph
by johnny_adidas » Wed May 10, 2006 11:13 pm
didnt try hitting the socket onto the bolt. dont have a blowtorch either. will try hammering next time as ill be putting on the braided hoses.
when you say soak them, i guess u just mean spray a load on and try again the next morning
johnny_adidas
by johnny_adidas » Wed May 10, 2006 11:21 pm
its 2 17mm bolts that hold it on to the strut, ya? just in case im trying the wrong ones
johnny_adidas
by dj_smurph » Wed May 10, 2006 11:41 pm
thought it was 7mm hex to get the calipers off the front struts
backs cant remember
yes soaked as in fully wet
dj_smurph
by johnny_adidas » Thu May 11, 2006 12:02 am
know the fronts are hex alright but it looked like the 17s were holding them on the back. cud well have the wrong bolts but it looked like those. must check TIS now
johnny_adidas
by johnny_adidas » Thu May 11, 2006 12:05 am
ya its def those 2 17mm bolts
johnny_adidas
by dj_smurph » Thu May 11, 2006 9:52 am
then soak them on wd over nite
dj_smurph
by johnny_adidas » Thu May 11, 2006 10:10 am
right thanks, will do. might try some diesel as well. failing that ill need to heat them up somehow. (obviously, not directly after the diesel [Ka-blam-o])
johnny_adidas
by dj_smurph » Thu May 11, 2006 10:17 am
its just rust and crap coatt the threads in copper grease before you put them back, thats why i like doing the work my self because when it comes to doing it the second time i know its gonna be easy
dj_smurph
by dicky » Thu May 11, 2006 10:39 am
Before you soak them try wacking them with a hammer and wack a socket on and try that.
By wack I dont mean tickle it with the hammer, I mean beat the **** into it.
dicky
by johnny_adidas » Thu May 11, 2006 10:54 am
after doing my f'n arb links last year, i think i know what kind of force you are suggesting hehehe!!
i reckon it was probably the previous owner when he painted the calipers cos i had the same prob when i was changing my rocker cover, bolts being overtightened and no grease used.
johnny_adidas
