Which alternator?
Which alternator?
by se6 » Wed Mar 23, 2005 9:01 pm
I have an 8v, what alternator do i need?
I read somewhere that as standard it would be 100A as i have aircon.
Then somewhere else it would be 70A. I want one with the largest output possible, can i get a 120A for my car? If not what is the largest that will fit?
Thanks
by Stupink » Wed Mar 23, 2005 9:03 pm
it depends which version of the belt you have, as far as im aware the thinner Vbelt comes in a 70a only, and the later 3/4 flat belt comes in 90 and 120a also....
not gospel tho, never really looked into it properly
by se6 » Wed Mar 23, 2005 9:06 pm
In that case i shall have a closer look at the weekend when i have got some time and see whats there at the mo. Mines a '96 which may mean its the later one that you talk of. Thnks for the speedy response
by Stupink » Wed Mar 23, 2005 10:02 pm
ahh yeh, i think all the later ones are the wider setup, although i don't know much about the 8v.. so you should be able to fit the 120amp just fine [img]/smile.gif[/img]
by Chavtastic » Fri Mar 25, 2005 9:27 am
120amp alternators are for Cally Turbo's and/or Aircon cars IIRC
by tb303 » Sat Mar 26, 2005 11:55 pm
i want a 120amp as well. have a 92 model with the thin toothed belt. i dont think that only 70a are available for these cars. how come they had preinstalled aircon with 70a? any ideas on where to get a 120a for my setup?
can the pulley on the alternator be replaced?
tb303
Users browsing this forum: Majestic-12 [Bot] and 20 guests
