where is the buzzer for the lights
Aye it is in the fusebox. The part no. for the older nasty sounding buzzer is 90 240 665, the newer two-tone sounding one is part number 90 464 777.
I have lifted this info from CavWeb, for more info click on the link below :-
<a href="http://www.cavweb-forums.co.uk/showthread.php?t=35" target="_blank">http://www.cavweb-forums.co.uk/showthread.php?t=35</a>
dazjb
<!--QuoteBegin-Kieran_Burns+--><div class='quotetop'>(Kieran_Burns)</div><div class='quotemain'><!--QuoteEBegin-->you mean the buzzer / two tone is in there?
Are they interchangeable?<!--QuoteEnd--></div><!--QuoteEEnd-->
If you mean can you change the old style buzzer for a new style two-tone one then yes you can, they just plug straight in.
You can also fit the nicer sounding buzzer from a Renault with a bit of wire swapping at the back of the fusebox, check here ....
<a href="http://www.cavweb-forums.co.uk/showthread.php?t=90" target="_blank">http://www.cavweb-forums.co.uk/showthread.php?t=90</a>
dazjb
