Speedo and Oil Gauge
Hi Guys,
My oil guage sometimes goes nuts, siting on over 5 bar, even on idle siting on 4 bar. To address this i've cleaned the connectors on the oil pressure sender, which only seems at times to fix the problem. Has anyone else had this problem and found a solution?
Also
The speedo seems to sit on zero and idle and tick between 0-10, on accleration it will initially sit on zero and then suddenly pop up to the right speed. Has anyone else had this problem and found a solution?
Thanks guys for your thoughts.
Also
Re: Speedo and Oil Gauge
BMJ wrote:Hi Guys,
My oil guage sometimes goes nuts, siting on over 5 bar, even on idle siting on 4 bar. To address this i've cleaned the connectors on the oil pressure sender, which only seems at times to fix the problem. Has anyone else had this problem and found a solution?.
change the sender unit
BMJ wrote:The speedo seems to sit on zero and idle and tick between 0-10, on accleration it will initially sit on zero and then suddenly pop up to the right speed. Has anyone else had this problem and found a solution?
could be the speedo cable or the speedo drive bit in the gear box ...cable is a bit harder to change than the gear box sender so would try that first ..its only plastic so might be worn
Thanks Fraz, I'll look into it.
