Heater Control Panel
by Calibra_Mike » Sat Sep 15, 2012 10:04 am
I can't remember as its been a while since I removed the control panel but is it an easy job to replace the light behind the panel? or is it a case of removing the whole panel? I do remember that being a right pig of a job.
Re: Heater Control Panel
by Allys Cally » Sat Sep 15, 2012 10:15 am
you dont need to take it right out but you will need a pair of tweezers or small nosed pliers to get the old bulb out
by Fraz » Sat Sep 15, 2012 10:42 am
easy enough to replace...its what has to come off to get to it
1. remove the steering coloum surrounds
2.remove the indicator and wiper stalks (the slide out once you press the clips top and bottom)
3. remove the bit of trim below the speedo clocks by grabbing in the middle and pull it towards you, allowing the two ends to disengage (sort of bend it in the middle)
4. remove the clock/fuel computer or D.I.D
5. take off the top speedo clocks trim (2 screws one each side)
6. now remove the other screws holding the heater control panel . one at the speedo end and two IIRC in where the clock/FC/DID was
you should now be able to pull the panel forward enough to see two purple wire about half way along the top (do not be confused by the purple wires at the side)
using long nose pliers you can then pull out the bulb holder and change the bulb
If i was you I owuld get a led one to go in rather than just a normal bulb...i used this and works just fine
http://www.ultraleds.co.uk/ultimate-286 ... n-232.html
by HOT-ROD » Sun Sep 16, 2012 12:24 pm
Anybody know how many bulbs you need to do the heater control panel?
by Fraz » Sun Sep 16, 2012 12:48 pm
just the one bulb
by HOT-ROD » Sun Sep 16, 2012 12:59 pm
Just the 1 for the heater display, direct knobs and the blower switch? :?
by Calibra_Mike » Sun Sep 16, 2012 1:27 pm
yeah just the one, which is why its such a pain when it blows lol
by HOT-ROD » Sun Sep 16, 2012 1:30 pm
Cheers lads will order 1 up now! :D
by Fraz » Tue Sep 18, 2012 10:19 pm
and it looks like this ...bad photo I know but you get the idea
by HOT-ROD » Wed Sep 19, 2012 7:28 pm
Where's your temp colour gone Fraz? :think:
by HOT-ROD » Sun Sep 23, 2012 1:49 pm
Well that was fun, just been on over an hour fitting the bulb time wasn't spent on the getting to it or the refitting the panel, but testing wires because it had no power to it.After half hour of testing I remembered the power didn't come from the sidelights but the ignition! :doh: but it's all done now and just waiting till tonight to see how it looks in the dark! :D
by Fraz » Sun Sep 23, 2012 2:21 pm
HOT-ROD wrote:Where's your temp colour gone Fraz? :think:
its there...just as I said a bad photo, the red and blue are a lot brighter than it is with just a normal bulb
by SAMARAI » Sun Sep 23, 2012 3:02 pm
When I bought my cali I didn't know the heater panel had illumination as only ones that came on were the A/C, air circulation and rear de-misters buttons.
After having the bulb replaced by my mechanic.. The dimer slider (the one under the low/high beam switch) that controls the brightness of the gauges doesn't control the heater panel lighting at all. The heating/cooling slider, fan on off, air at feet, air at face and front de-mister/full air are always on if ignition is on. How can I fix this?? Is it the way the mechanic got the bulb to turn on and off? Ie the wiring?? Why can't I dim the Center control panel lights??
via Tapatalk 2 for Galaxy Mini ;)
by HOT-ROD » Sun Sep 23, 2012 3:07 pm
Thats how their wired up mate they work off the ignition and all the others work of the sidelights thus being able to dim them and not the heater controls!
by SAMARAI » Sun Sep 23, 2012 11:42 pm
It seems silly though that the fan controls and slider controls are not dimmable. So on all Calibras its like this?
