knock sensor
knock sensor
by stevo turbo » Tue May 04, 2010 7:58 am
rite started to strip down the c20 let the other day to do the timing belt. removed the airbox and found the wire going to the knock sensor was rubbed through on the aux belt. i need to know if the same sensor is used in the c20xe as i have a spare one sitting at home before buying one
Im assuming its knock sonsor- its in the middle of front of block so behind turbo.
cheers
Re: knock sensor
by Phantom » Fri May 21, 2010 5:17 pm
that maybe the crank sensor, have you got a pic?
Re: knock sensor
by bodgetastic » Fri May 21, 2010 5:19 pm
Knock sensor is below the inlet so sounds like crank sensor to me below the thermostat
Re: knock sensor
by stevo turbo » Sat May 22, 2010 12:31 pm
yep it is the crank sensor, got new one now and gonna fit this weekend
