Code 71 and 73 on Ecotec 16v
by eco16v » Sat Feb 27, 2010 7:58 pm
Replaced the rubber ducting that the air intake temp sensor fits into today as old 1 was split, started car up and on came my old friend Mr EML. Flashed the codes and got 71 - Air intake temp sensor voltage high and 73 - Mass airflow temperature voltage low. Checked connections, cleaned intake sensor but still the light was on, took car for a drive and switched it off, then on again and light went off, let car sit for an hour or so but when i restarted on came the light again Any ideas what to do next?
eco16v
Re: Code 71 and 73 on Ecotec 16v
by James_Mould » Sat Feb 27, 2010 9:33 pm
Have you checked all the wires? Maybe theres a break causing the fault. Make sure theres no air getting in after the sensor too as that could confuse things.
by MarkSE7 » Sat Feb 27, 2010 10:41 pm
Disconnect the battery for 10 mins to clear the faults and see if they come back on. Did you have the ignition on with the sensors unplugged?
MarkSE7
by eco16v » Sun Feb 28, 2010 4:54 pm
Checked all wiring, everything seems ok, tried clearing the codes but no use. Everything was left unplugged overnite when i removed the old ducting tho.
eco16v
by Calibra_Mike » Sun Feb 28, 2010 8:11 pm
I had a problem like this on my old 8valver, was getting fault codes coming up telling me it was the airflow meter... I spent ages trying to sort it out, tried three different AFMs, in the end I ended up testing the wires on the cable going to the AMF and found two wires had really high resistance on the multimeter but would change when i wiggles the wires, turned out that some of the wires must have had slight brakes in them, re-wired it and problem stopped... not saying this is your problem but dont rule of dodgy wires... invest in a good multimeter or ur be :banging:
by eco16v » Sun Feb 28, 2010 10:40 pm
Just to make thing a bit more interesting today, when the engine is warm and u switch the car off and then on again the eml goes off, but if u leave the car for say an hour or so and the engine cools down then the eml comes on again as soon as u start the car up.
eco16v
by eco16v » Mon Mar 01, 2010 11:27 pm
Ok problem seems to be sorted, disconnected sensors and battery last nite and left it until this evening. Reconnected sensors and then battery, started her up a few times and all seems to be well. Hopefully its cured, but time will tell!
eco16v
Users browsing this forum: No registered users and 64 guests
