Fault 49 Battery Voltage High
Got this fault come up. Any ideas on how to fix it?
Brgds Suky Saggi
Brgds Suky Saggi
SukySaggi
Re: Fault 49 Battery Voltage High
Measure the voltage across the battery with a meter, while the engine is running. The fault code is only flagged if the voltage is greater than 16v.
Usually means the regulator pack in the alternator has failed.
How to fix it?? New alternator time.
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
I now own this one.
Yep, looks like a new alternator is needed. Any idea what amp my currant one is? It's for a C20LET with air con.
Will it say the amp rating somewhere on the alternator?
Brgds Suky Saggi
PS Whats the price likely to be?
Brgds Suky Saggi
SukySaggi
