oil level light
oil level light
orange oil level light is currently burning in my cally, oil level is correct on dipstick, anyone know what might be causing this? Have been told it could be the oil level sensor or oil pressure switch, any ideas?
eco16v
Re: oil level light
level sensor, if you want light out just disconnect it
Re: oil level light
Fraz wrote:level sensor, if you want light out just disconnect it
bit dodgy is it not?
Re: oil level light
1st thing I'd do it clean the connection on the sensor wire
Re: oil level light
jamseyboy5 wrote:Fraz wrote:level sensor, if you want light out just disconnect it
Not really as you have the other sensor to check oil level ................... dip stick.
Re: oil level light
Mine come son now and again since the rebuild, Like Robbie says, I check the dipstick every every few days. and nothing is wrong, so i just ignore it.
A new sensor isnt cheap for what it is.
Re: oil level light
why all you do is open the bonnet and pull a wee stick out wipe it then re-insert it and lo and behold you know the level of your oil...and much more accurate than a silly wee light
unless your the lazy type ...or have no arms
Re: oil level light
i like the idea of everybody freaking out when a warning light appears lol
michael tucker
Re: oil level light
when the light comes on its usually too late for the engine thats why i use the dipstik my light comes on and off all the time and theres oil and loads of pressure
Re: oil level light
Tried disconnecting it, light stays on even when disconnected, any other ideas?
eco16v
Re: oil level light
Disconnect and bridge teh wires. Failing that, remove the sensor and clean that up. Maybe its a little sticky.eco16v wrote:Fraz wrote:level sensor, if you want light out just disconnect it
Markp
Re: oil level light
The oil level light will stay on you just disconect the sensor. Just take the bulb out, forget about it and do what the others sugest using the dip-stick.
Re: oil level light
Just a quicky, to remove that sensor in the front of the sump, does it twist and pull or is it clipped in?
MarkSE7
