no ignition light on dash??????/
ok peeps Fraz got it rite! my charging circuit has a fault on my se9. only problem is now i have changed the bulb for a good one and it still dont light up????????????
so no ignition light!!!!!! anyone got any ideas?
rob.
rob.
flat-eric
Re: no ignition light on dash??????/
eh there is a break in the circuit from alternator to the bulb. I think that will go to the large round connector down by the battery ...could be the wire has broken there
or as he said ...a FUSE
checked wires and fuses, and the bulb is ok................
hmmm next idea?
cheers for the help guys
rob.
if i fix this its getting mot asap as i want her for work! lol
hmmm next idea?
rob.
flat-eric
Is there power to the live side of the fuse? Put a tester in the fuse socket
callyman wrote:Is there power to the live side of the fuse? Put a tester in the fuse socket
which fuse?
have got car on axle stands now and just removing heat shield from it.
rob.
I WILL NOT BE DEFEATED!!!!!!!!!!!!!
flat-eric
good luck with that
cant reach just yet but from what i can see there are two terminals on the altinator (one large - one small)
now the multimetre is getting 12v from the large one with ignition on. is this correct?
rob.
rob.
flat-eric
no thats direct to the battery, its the smaller one you want
ok with the two wires wired up i get 12v on the large one and the smaller one is earthed.
turn the ignition on and the smaller one is then 12v and large still 12v
is that how it should be?
rob.
going to disconnect the smaller wire now and test.
rob.
flat-eric
what fuse am i looking for ? once i've checked this?
flat-eric
ok with the small wire disconnected and the ignition on it is getting 12v, once ignition is switched off it is earthed again.
rob.
rob.
flat-eric
yup ...guess you better haul the dash out and check that then
Fraz wrote:yup ...guess you better haul the dash out and check that then
ok dash out, now what?
the bulb is ok, i asume its the one the same size as a side light yeh?
i cant get dash completely out due to wheel in the way.
rob.
flat-eric
no its a very small bulb and its in a holder, it will be in the bottom of the dash
Users browsing this forum: Bing [Bot] and 3 guests
