oil pressure/volt meter gauges
hi guys.....just bought a oil pressure and volt meter gauge for the cally, is it easy to install?....are the connections automatically put in place or would it need rewiring??
cheers guys
cheers guys
J570_BOO
Re: oil pressure/volt meter gauges
yes they just clip inJ570_BOO wrote:hi guys.....just bought a oil pressure and volt meter gauge for the cally, is it easy to install?
J570_BOO wrote:are the connections automatically put in place or would it need rewiring??
needs rewired unless your car did come fitted with, you will need the connector for the gauge (with some wire ..would be handy)
the duel pressure sender and switch
if you remove your cd player you should find a small balck 3 pin coneector taped up, if it's not there then you will have to wire it in
oh and moved to the correct section for such questions....we do have more than one section you know, one is called TECHNICAL
which is the correct section
doubtful it will have the connector on a J plate car
I beleive the sensor for oil pressure should already be there
vectrasimonsri
well theres no way i can do it lol...ill have to pay someone to sort lol...cheers
J570_BOO
