se9 not charging.
se9 not charging.
hi peeps, just got my se9 home after nursing her the last mile ish.
electrical problem relating to the alternator, previous owner had a recon one fitted and after having a quick look today it looks new.
put a good battery on and she read 12.8v on the multimetre. started the car up and she read 12.4 and started to drop very slowly.
what should be my next course of action?
rob.
rob.
flat-eric
Re: se9 not charging.
sounds like the alternator is not working, easy way to check is open the door leave the interior light on ...rev the engine and watch the light, should get brighter as you rev...if not then alternator is faulty (common fault on a V6) or have you meter across the battery and rev the engine and see if the voltage goes up
how long ago was this one fitted?? and you best also check the alternator cooling fan is working...its under the long plastic bit coming from the right side of the engine, take the plastic bit off and you will see the cooling fan, see if it spins freely ...if not your going to need one of those as well (another common problem) and they are not easy to come by (Usually)
Fraz wrote:sounds like the alternator is not working, easy way to check is open the door leave the interior light on ...rev the engine and watch the light, should get brighter as you rev...if not then alternator is faulty (common fault on a V6) or have you meter across the battery and rev the engine and see if the voltage goes up
have done what you say and no its obviously not not charging at all rev rev and no change on either lights or metre.
the alti is a recent recon fitted by a previous owner, but it seams it may have been fitted incorrectly or is a duff one.
whats the best way to attack this? get it up on ramps and go from underneath?
rob.
flat-eric
Oh this is not a job for the faint hearted!!! and will be a few swear words
you need to get under the car to get it out ....and even then its what else you need to take off to get to the damn thing and get enough room to get it out
not having a V6...its only been once I helped
there is two ways one is remove the O/S strut and get to it that way
but IMHO the easier way is from underneath, you will still have to at least drop the centre drive shaft support, no doubt the V6 people will tell you what else
oh does the ignition light come on??? just if not believe it or not of the bulb is blown the charger circuit will not be complete ..thus wont be charging the battery
Fraz wrote:oh does the ignition light come on??? just if not believe it or not of the bulb is blown the charger circuit will not be complete ..thus wont be charging the battery
ignition light when?
im excited now at an easy fix possibility!
im a pretty competent amature mechanic and have done engine and gearbox swaps a restored a 1980 mini so getting stuck in isnt a problem but the cold weather is coming!
any help or advice much appreciated!
rob.
flat-eric
didnt i say it would be your alternator last night
as fraz says your best to drop it down it will take a good hour theres not much room enjoy
when you turn the key on...does the ignition light come on??
v6 steve wrote:didnt i say it would be your alternator last night![]()
day off tomorrow so i think i'll get stuck in and have a look!
anyone with pics of what i'm looking for would be a bonus!
it is a new / recon unit on there so im hoping its just wired up wrong! or not connected properly.
if not then i dunno whether to try another unit but that will cost a bomb!
rob
flat-eric
Fraz wrote:when you turn the key on...does the ignition light come on??
cant check now the battery flat! lol will check with my spare tomorrow.
if no bulb is it just a case of dash out and replace?
rob.
flat-eric
Users browsing this forum: No registered users and 91 guests
