Where is my fuel fuel pump relay
On a '97V6
Re: Where is my fuel fuel pump relay
Behind drivers side lower kick panel.
In with the fuses?
Which one is the fuel pump relay ??
J3LLY wrote:In with the fuses?
No not with the fuses, There is a kick panel by your right foot its behind that.
http://www.v6calibra.net/docs/fuel_pump_relay.htm
Behind the kick panel, not the fuse box.
Having trouble getting a Fuel Pump Relay
Chassis number is W0L000085V9005134
Is vauxhall part 90378651 the correct replacement
Confused as this part covers all Calibras and other models
Would of thought it would be different on a V6
That's the correct part number and it does indeed cover all Calibra's.
Thanks Robbie
