blowers not good
blowers not good
hi, my calibras blowers dont work very well, i put them on full & it makes a loud deep whirling noise & takes forever to de-steam my windows, i also open the air vents & cant feel much air coming out. does anyone know the problem???
frankej
Re: blowers not good
If you are sure the fan is working then it'd prob not that. Have you got a pipe off somewhere behind the dash? that would some of the pressure away from the others
i'll have a poke about when the rains off, if it goes off
seems like a pipe's missing but the blower makes more noise than in the last 2 i had
frankej
had this with mine before, check the pollen filter there's a good chance it either full of crap or it's saturated with water
Allys Cally wrote:had this with mine before, check the pollen filter there's a good chance it either full of crap or it's saturated with water
hi ally, is the filter the bit under the plastic casing where the blower is?
frankej
pop the bonnet lift the plastic panel and it sits inbetween the wipers
could be the cable has come off the heater sliders and its stuck between window and floor, or any of the others
thought about that as well Fraz but thought it be better checking the filter first before ripping the heater panel out
no I would check the filter first as well
i'll have a look when the weathers better, its getting dark now & the rain is still heavy
frankej
dont know, just a little comes out the air vents when blowers on full & blowers make hell-ov-a-noise
frankej
thats what mine was doing you'd have it on full and there would be little or no air at all. i whipped the fiter out and it was like a force 10 gale coming out the vents. the fiters are only a fiver to replace. try the fiter first mate then you'll know if it ain't it then it's your heater panel
as ally has said it will be the filter
i remeber some one hand a mouse nest in one
yes can remember emptying it onto your garage floor
i had a poke about & the filter looks almost black, found a couple of leaves on top of it & a few small stones on top. plus i noticed the wiper arms have damaged some of the filter too, is that normal?
frankej
