paper clip test code 34
by TommyTT » Sun Nov 09, 2008 3:32 pm
hello newbie here.
I have just done the paper clip test and it came up with code 0340 this in a low voltage map sensor issue.
Could someone pls tell me how to fix this issue pls?
Thanks in advance Tommy
TommyTT
by tazz666 » Sun Nov 09, 2008 6:41 pm
hi and welcome to the club mate some one will be along shortly who will help you with the problem
tazz666
by Phantom » Sun Nov 09, 2008 11:56 pm
hi there and welcome along, can you tell us what engine you have there and what year your car was registered
by TommyTT » Mon Nov 10, 2008 9:46 am
yes its a 1996 p x20xev
TommyTT
by TommyTT » Wed Nov 19, 2008 3:30 pm
can anyone help please
TommyTT
by TommyTT » Wed Nov 19, 2008 3:45 pm
thank you for your help
TommyTT
by TommyTT » Wed Nov 19, 2008 3:55 pm
yes it flashed 10 times then 3 then 4 then 10
TommyTT
by BazV6er » Wed Nov 19, 2008 3:58 pm
10 flashes,3 flashes,4 flashes,10 flashes =code 0340 cam sensor
http://www.cavweb-forums.co.uk/showthread.php?t=155691
by TommyTT » Wed Nov 19, 2008 3:59 pm
will change that this weekend thank you all for your help
TommyTT
by BazV6er » Wed Nov 19, 2008 4:01 pm
the cam sensors are a pain as they come under various part numbers and if the wiring loom has been modified then its more expensive to replace , vauxhall quoted us £63 for just the sensor and autovaux do the wiring loom and sensor for £38
by Joker » Wed Nov 19, 2008 7:58 pm
my xe flashed up 34, when i got my knock sensor and icv mixed up i switched them around and it went!
Joker :)
Joker
by MickM » Wed Nov 19, 2008 9:39 pm
before you cahnge the sensor, check the connection and clean it up... sometimes saves a few quid...
MickM
by ferret1985 » Thu Nov 20, 2008 12:20 am
been flicking through e-bay plenty of cam shaft sensors on there. Not sure if there's any new ones though.
ferret1985
by BazV6er » Thu Nov 20, 2008 1:04 am
personally ive been told before to get a cam sensor from genuine vauxhall specialists as the ebay ones could be ok /might not be ok as these are mainly from china.
Users browsing this forum: No registered users and 44 guests
