ecu light staying on while driving
by paudie » Mon Feb 11, 2008 10:31 pm
anybody no why the ecu light is staying on while i drive?? car running like s**t now,slight pause while foot down goin tru the gears,ideling high+failed nct on very very high emishons=[did paper clip test last week and crankshaft sensor came up but car starts most of the time!! driving a 92 4x4 turbo
paudie
by Phantom » Tue Feb 12, 2008 2:39 pm
if the light is on the ecu will be in safe mode which won't allow you to rev the engine thus protecting it, if the test showed the fault to be the crankshaft sensor have you not replaced it? did you do the test with the engine running?
by paudie » Thu Feb 14, 2008 6:46 pm
havent had the money to get the crankshaft sensor,next week. engine was running but if the crankshaft sensor is faulty shouldnt that prevent the car from starting??
paudie
by paudie » Sat Feb 16, 2008 2:43 pm
just got round to paperclip test again with car running,code 42 and 73 came up...
42 -a- vehicle speed sensor(vss)high voltage
42 -b- 1gear ident switch(c20let systems)high voltage
42 -c- est line coil cylinder 2+3(m2.8/xev system) high voltage
73 - air flow sensor (afs) low voltage
i presume one of these faults is causing ecu light to stay on and why my car is running like s**t!? what parts will i need to get to sort my baby out??
paudie
by paudie » Sat Feb 16, 2008 3:04 pm
oh and 4x4 light on aswell!any ideas??
paudie
Users browsing this forum: Bing [Bot] and 13 guests
