Brake lamp on dash
Brake lamp on dash
Hi all,
Sorry to be a pain in the a55 again but the brake warning lamp on the dash comes on as soon as I start the car. This has been the same since I got it. The lad who I bought the car off says that the handbrake cable needs sorting on the passenger side rear. Would this be the cause of the lamp being on? Its only because when I depress the brake pedal (I mean push it in - not tell it that it needs counselling or anything lol) the lamp goes out until the next time I start the car.
Any ideas?
Jon
Any ideas?
Jon
jonboy78
every day's a school day, eh jon
jonboy78 wrote:Just never seen that on a car beforeAlways had cars that did an internal check and then flagged it up via the dash lamp if there was a problem.
That's exactly what the Calibra does - its called a check control system.
When the ignition is switched on all check control lamps light up, If all the monitored systems are ok they go out again after around 4 seconds.
The brake fluid level indicator goes out when the engine starts to run. The brake lamp indicator goes out once the lamps have been checked by the check control system following operation of the brake pedal.
jonboy78
