my fault coads
my fault codes
by ian » Thu Jun 15, 2006 7:16 pm
well since theres a few ppl doing them i thought i would see what was brought up and i got these
code 31- engine rpm signal (crankshaft sensor) - could this be why my speedo dont work? remady if anyone noes.
code 145- incorrect immobiliser signal recived - not got a clue ? have u ?
cheers guys if anyone can help that would be good [img]/smile.gif[/img]
ian
by EY » Thu Jun 15, 2006 9:49 pm
31 just means the engine was not running when you did the test, not sure about the immobiliser one.
by v6calibra » Thu Jun 15, 2006 9:58 pm
<!--QuoteBegin-ian+--><div class='quotetop'>(ian)</div><div class='quotemain'><!--QuoteEBegin-->well since theres a few ppl doing them i thought i would see what was brought up and i got these
cheers guys if anyone can help that would be good [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
are you sure 145 is right coz my book hasnt got a code that high
v6calibra
by thecrow » Thu Jun 15, 2006 10:51 pm
Yeah I don't know 145?
thecrow
by hoglabs » Fri Jun 16, 2006 12:02 am
For late V6 ECU's 145 is a valid code:
<a href="http://www.v6calibra.com/motonic/v6calibra_motronic_faultcodes.htm#145" target="_blank">http://www.v6calibra.com/motonic/v6calibra...ltcodes.htm#145</a>
hoglabs
by ian » Fri Jun 16, 2006 9:40 am
ah so looking at that hoglabs thats why my speedo dont work.
but what does it mean is wrong with it?
ian
by jimbo1979 » Fri Jun 16, 2006 10:28 am
It says:
Intermittent faulty wiring/connectors on speedo circuit
jimbo1979
by ian » Fri Jun 16, 2006 10:32 am
yer but my speedo ait working full stop and ive had it out and checked the connections?
may have to replace the cabel if that broken somwhere
ian
