v6
v6
my ecu light is on in my corsa ive flashed the codes and they are the following
16 - which i think is the knocksensor 1 (where is this located??)
13 - oxygen sensors (ive got a wire lose i know about)
31 - RPM signal ( crackshaft sensors) ?
would a dodgy oxygen sensors cos any of these or not ? (apart from 13)
D_a-RR-e_N
This website will show you all you need to know about ECU faults, codes and sensor locations [img]/smile.gif[/img]
<a href="http://www.v6calibra.com/motonic/v6calibra_motronic_faultcodes.htm" target="_blank">http://www.v6calibra.com/motonic/v6calibra..._faultcodes.htm</a>
<!--QuoteBegin-callymental+--><div class='quotetop'>(callymental)</div><div class='quotemain'><!--QuoteEBegin-->I have been trying to fix this on mine code 16.
Have been suggested to wd40 the contacts, and reconnect. There is a known fault in the wiring loom for this sensor. Will be putting mine back together later this evening, fingers crossed.<!--QuoteEnd--></div><!--QuoteEEnd-->
Also, make sure its torqued up to the exact correct torque setting - they're very delicate in the way they work so it has to be spot on.
You're right though, the wiring gets screwed as it runs over the engine, gets hot, and breaks down.
thecrow
<!--QuoteBegin-D_a-RR-e_N+--><div class='quotetop'>(D_a-RR-e_N)</div><div class='quotemain'><!--QuoteEBegin-->no go tryed cleaning it up and it ticks over ok, but as soon as i put a bit of throttle on the ecu light comes on again. if i get a new knock sensor willl this solve the problem ?<!--QuoteEnd--></div><!--QuoteEEnd-->
did you disconnect the battery for 1/2 - 1 hour after you cleaned the connection, you need to do this to clear the fault code, try it after you have d/c'd the battery to make sure before you go ordering new sensors
Cozy
Users browsing this forum: No registered users and 106 guests
