Oil light warning
Oil light warning
by Welsh_Andy » Tue Jan 03, 2006 11:33 am
the amber oil light warning is coming on,yet oil change was done only 2 wks ago.its an intermittant prob.
dodgy sensor maybe?
Welsh_Andy
by Spearmint » Tue Jan 03, 2006 11:35 am
Low level sensor in your sump.
Spearmint
by Smurf » Tue Jan 03, 2006 1:10 pm
Did you put the same grade of oil you normally use in? Last year I put some thinner than normal oil in the V6 and that light kept coming on. I went back to my usual, and it's not come on again since. I can only think the thinner oil I used was too thin for the sensor to properly detect it.
Smurf
by Welsh_Andy » Tue Jan 03, 2006 3:45 pm
<!--QuoteBegin-Smurf+--><div class='quotetop'>(Smurf)</div><div class='quotemain'><!--QuoteEBegin-->Did you put the same grade of oil you normally use in? Last year I put some thinner than normal oil in the V6 and that light kept coming on. I went back to my usual, and it's not come on again since. I can only think the thinner oil I used was too thin for the sensor to properly detect it.<!--QuoteEnd--></div><!--QuoteEEnd-->
i always use vox 10W40 mainly cause its gd stuff,plus its less than a tenner with TC
Welsh_Andy
by malcolm_jamesuk » Tue Jan 03, 2006 4:09 pm
Mine did exactly the same ....and turned out to be a dodgy sensor in the sump.. it should not matter rearly what viscosity the oil is for it to sence it as it works on oil level....
regards and happy new year
malcolm_jamesuk
by Welsh_Andy » Tue Jan 03, 2006 4:53 pm
well if its sensor,it be the 1st to go down.hope this isnt the start of a free for all sensor failure:sob:
Welsh_Andy
Users browsing this forum: No registered users and 77 guests
