Foglight wiring
Foglight wiring
Is the wiring needed for the foglights fitted on all Calibras? Just curious because the wiring for the switch is there, and I plan on fitting headlights with foglights.
King Calibra
<!--QuoteBegin-King Calibra+--><div class='quotetop'>(King Calibra)</div><div class='quotemain'><!--QuoteEBegin-->Would you be able to snap a photo of where it's supposed to be?<!--QuoteEnd--></div><!--QuoteEEnd-->
The switch for height adjusting is just to be plugget in. No relays are needed.
Very close to each headlamp is this connector:
<a href="http://www.calibra.dk/lex/img_2325.jpg" target="_blank">http://www.calibra.dk/lex/img_2325.jpg</a>
It's to be connected to height adjustable motor on headlamp
cheers Proxie
cheers Proxie
Proxie
<!--QuoteBegin-Proxie+--><div class='quotetop'>(Proxie)</div><div class='quotemain'><!--QuoteEBegin-->The switch for height adjusting is just to be plugget in. No relays are needed.
cheers Proxie<!--QuoteEnd--></div><!--QuoteEEnd-->
Actually, I meant the connector for the foglights.
King Calibra
