help needed for total closure
by wilza0 » Sat Jun 18, 2005 8:22 pm
i have had my cobra alarm system for a year now but the one thing that has alwasy bugged me is that i know it can close the windows but the guy who fitted it never wired it up i have just had a late spring clean and came across the instruction manual and i have read it but not sure on the wires needed i have BROWN/WHITE for window closer output what else im i looking for and also what color wires do i need to connect to on the calibra 93redtp on a L reg many thanks will
wilza0
by jimbohotpants » Sat Jun 18, 2005 11:26 pm
I thought I told you that before mate? You need to find the Brown/Black wire in the driver's footwell behind the kick panel. This is the total closure wire. It will only work with the door microswitches connected.
jimbohotpants
by jimbohotpants » Sat Jun 18, 2005 11:27 pm
That's the only wire you need to splice into by the way;)
jimbohotpants
by jimbohotpants » Tue Jun 21, 2005 5:22 pm
How you gettin on mate?
jimbohotpants
by wilza0 » Tue Jun 21, 2005 6:37 pm
right then i have done what you said i pulled all the carpet back took out the kick panel and found the loom comming from the door grommet i used a test light plugged one end to the door to earth and prodded the cabels with the pin found two black/brown wires finally the door locks went and the windows went up great so stripped out the other side and and looked for the cobra system wire but when connected the made up wire to go between nothing now im stuck any ideas wold be great as i know you can do it cheers will
wilza0
by 4x4Turbo » Wed Jun 22, 2005 11:21 am
im pretty sure you have to have the control unit with the cobra alarm its a seperate module im pretty sure thats what mines got, might be worth just running it into a cobra insatller they'll probly do it in 10 secs and just give the bloke a drink!
4x4Turbo
by 4x4Turbo » Wed Jun 22, 2005 11:22 am
im pretty sure you have to have the control unit with the cobra alarm its a seperate module im pretty sure thats what mines got, might be worth just running it into a cobra insatller they'll probly do it in 10 secs and just give the bloke a drink! also i think you have to program the cobra alarm to turn on the window closure
4x4Turbo
