New Clifford alarm fitted
by VivSE5 » Mon May 23, 2005 5:37 pm
Hi guys and gals,
as the title says, had clifford alarm fitted,
but the proximity sensor isnt doesnt go off when you are near the car,
any body know how to set it? or change the proximity on it?
Its a concept 650.
cheers...
VivSE5
by Admin » Mon May 23, 2005 6:32 pm
It is dealer adjustment only, it is part of the install, pop it back to the people who installed it and they will do it for you, only takes a minute to do.
Admin
by VivSE5 » Mon May 23, 2005 6:34 pm
Ok thanks for that..
VivSE5
by Admin » Mon May 23, 2005 6:36 pm
If you ask them nicely they may tell you how to to do it [img]/wink.gif[/img] but it is very easy to get into a mess and make it far too sensitive!
Admin
by Stupink » Mon May 23, 2005 6:39 pm
you can buy the datalink cable/cd from them for about 15-25quid i think then you can just plug in your laptop and ajust everything whenver u like [img]/smile.gif[/img]
by Admin » Mon May 23, 2005 6:45 pm
<!--QuoteBegin-Stupink+--><div class='quotetop'>(Stupink)</div><div class='quotemain'><!--QuoteEBegin-->you can buy the datalink cable/cd from them for about 15-25quid i think then you can just plug in your laptop and ajust everything whenver u like [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Not everything unless you have the installer version.
Admin
by Stupink » Mon May 23, 2005 6:48 pm
oh. my bad. thats a bit of a con then isnt it [img]/smile.gif[/img]
by Admin » Mon May 23, 2005 6:58 pm
Not really, as it is a lot easier than sitting out there and trying to program it over the valet switch, not that i have ever been there or done that you know [img]/wink.gif[/img]
Admin
by VivSE5 » Mon May 23, 2005 7:01 pm
So not the best choice of alarm then!!!!!!
VivSE5
by Admin » Mon May 23, 2005 7:04 pm
<!--QuoteBegin-VivSE5+--><div class='quotetop'>(VivSE5)</div><div class='quotemain'><!--QuoteEBegin-->So not the best choice of alarm then!!!!!!<!--QuoteEnd--></div><!--QuoteEEnd-->
It is a good choice of alarm, I will use a Clifford alarm every time that I get a chance.
I have had very few problems with any of the Clifford alarms i have had, and i have been using them for 10 years almost now.
Pop down to your local dealer they will probably do it for you while you wait, it literallt is only a 30 second change to make, just make sure that you take the master remote control with you.
Admin
by gazcallyt » Wed Jun 01, 2005 1:26 pm
I set mine up via the valet code and the remote, the options you need are not listed in the normal guide you get, I have a installer version somewhere that tells you how to adjust the range via the remote, its for a 600 but it will probably be the same.
Let us know if you need a copy.
Gary.
LET the fun begin.
by haroldhettaturbo » Wed Jun 01, 2005 2:57 pm
Hi m8
Do you have that guide on you pc, iv lost my clifford 600 book.
Can you email it to
<a href="mailto:lordluvrocket@gmail.com">lordluvrocket@gmail.com</a>
Thanks
HH
haroldhettaturbo
by Tattooman » Thu Jun 02, 2005 6:24 pm
i got a concept 400 and i can change the proximity sensor via the remote! surely this can be done with yours too,no?
Tattooman
by Admin » Thu Jun 02, 2005 6:36 pm
<!--QuoteBegin-Tattooman+--><div class='quotetop'>(Tattooman)</div><div class='quotemain'><!--QuoteEBegin-->i got a concept 400 and i can change the proximity sensor via the remote! surely this can be done with yours too,no?<!--QuoteEnd--></div><!--QuoteEEnd-->
It can be, you just need to ask the dealer nicely to tell you how to do it [img]/wink.gif[/img]
Admin
by bodgetastic » Thu Jun 02, 2005 7:14 pm
yea, its quite simple to do using the master remote, I have done it a few times but cant find the sequencing anywhere for mine, otherwise I would let you know. Don't make it too sensitive though, mine was forever going off at one point and the neighbours really wern't happy lol !
