Car unlocks itself as soon as i lock it.
If i unlock the car from the drivers side it doesn't unlock the passenger door, but the boot and petrol cap unlock ok.
If i unlock the car from the passenger side everything unlocks including the drivers door.
This works the same way when locking the car.
For me to lock the car from the drivers side the passenger lock must be locked but if i lock the car from the passenger side it locks everything perfectly.
From this can you indicate which lock is at fault?
Before i take the passenger door appart [img]/laugh.gif[/img]
bish
RE: up up and...
Pass i have remote central locking so i press a button and they lock. As a guess sounds like passenger door to me probably the central locking micro switch. Someone mentioned this earlier in this thread i think that the micro switch could be broken or earthing so worth giving a clean.
There isnt much to the system but is not the easiest thing to get to if you have to get the whole thing out.
Have a look here: <a href="http://www.max-boost.co.uk/max-boost/resources.htm" target="_blank">http://www.max-boost.co.uk/max-boost/resources.htm</a> and the locking doc shows how basic it is
gremlin
