lower temp radiator thermostat fan switch
Re: lower temp radiator thermostat fan switch
viewtopic.php?f=16&t=40992
it didnt overheat so much before fitting the fmic.
i flushed the cooling system 2-3 months ago.
i havent replaced my thermostat. i think GEMA has what i need
vaggelis00
so the fan wont kick in m8, try replacing the fan module seen it done the the garage on discovery turbo
If it's not broke, fix it until it is...........
im not sure m8
James101 wrote:im not sure mate
Good advice
James101 wrote:so the fan wont kick in mate, try replacing the fan module seen it done the the garage on discovery turbo
this was done on a VW golf like lol so im just thinking is it the same for all cars with A/C
i really have no idea about it. yesterday i removed the thermostat from the engine and i'll see how thing going now
vaggelis00
hi mate like i sed before u should fit a cool running thermostat and u havent sed if the oe intercooler is still in place
steve08
It sounds to me like you may have a small overheat prob that came along at the same time as the fit of an FMIC, I have a/c and FMIC and no probs on stock thermostat, how hot is it where you are?
moosebuster1st
i live in Greece and the summer is really hot. like 35-40 celsius. the prob is that the second scale of the fan starts at 120 degrees. i need to find a fan switch to start lower like 1 scale 95 degrees and second 105
vaggelis00
i think only gema motorsport had a switch like this but they dont sell it anymore
vaggelis00
How is it running woithout the thermostat in?
If its ok, then the thermostat was shot and not opening fully. get a new STD one.
its the same with or without the thermostat, both ways the engine temperature is very very high
vaggelis00
If it's getting really hot without a thermostat then what good would a cool running stat make?
Sounds like you may have a huge air lock or semi blocked water ways. (if your lucky)
i have no prob with the water pump like leaks or some noise. temp was checked through TECH1 and the temp gauge was ok. my headgasket was repaired at EDS in 2004 but i dont know what job was done.
callyman what do you mean by huge air lock?
vaggelis00
