fuse
by vinny_69 » Sat Aug 30, 2008 5:58 pm
you get all defensive when i go on about you being erm weathered ha ha
but it's ok for you to do it :monkey:
is my car still useable till the flasher relay gets replaced?
vinny_69
by RAINMAKER » Sat Aug 30, 2008 6:02 pm
no flasher relay, does'nt that mean no indicators!! no way of warning other motorists therefore hand signals mate..
And you can call me old anytime mate...just for the record just phone me anyway anytime..yeah
RAINMAKER
by vinny_69 » Sat Aug 30, 2008 6:08 pm
i thought it might run something else, no worries i shall drive home then wooohoooo and get one tomorrow
vinny_69
by paradog » Sat Aug 30, 2008 7:24 pm
Had this problem about a month ago press the hazard switch a couple of times and see if it clears
paradog
by vinny_69 » Sat Aug 30, 2008 7:40 pm
paradog wrote:Had this problem about a month ago press the hazard switch a couple of times and see if it clears
did it stop buzzing when you started the car and everything work as normal? but i will try it tomorrow see what happens
vinny_69
by paradog » Sat Aug 30, 2008 7:50 pm
Yep worked great but only after i switched the relay and indicator stalk.But to prove a point i put old parts back on and everything was still ok in fact it satrted playing up after i had cleaned the car.
paradog
by vinny_69 » Sat Aug 30, 2008 8:27 pm
sound exactly the same cheers DOG :monkey:
vinny_69
by vinny_69 » Mon Sep 01, 2008 2:13 pm
cheers paradog i put the fuse back in today and no noise worked just fine went for a drive turned off the ignition and bzzzzzzzzz hit the hazard lights a few time and silence \:D/
vinny_69
