Mystery lead/sensor
aha, it seems I do have a factory fitted alarm I had no idea about. I looked through the security manual and realised I didn't know the procedure for deadlocking, so I deadlocked and looked for the red flashing light. Tested it by popping the bonnet and deadlocking to find it set the hazards off but not the horn. Yet another problem to tackle.
Doesn't help with the mystery lead problem though as the diagram of the alarm here ( <a href="http://www.v6calibra.com/alarm/v6calibra_atas.htm" target="_blank">http://www.v6calibra.com/alarm/v6calibra_atas.htm</a> ) shows nothing like it under the bonnet.
Anyone know where the pins mentioned on the above site can be found to get a fault code?
dan1w
<!--QuoteBegin-Fraz+--><div class='quotetop'>(Fraz)</div><div class='quotemain'><!--QuoteEBegin-->or is your car fitted with headlamp washer jets?<!--QuoteEnd--></div><!--QuoteEEnd-->
It is, yeah. Can't see how this would be anything to do with them though 'cos the wires at the end are incased in plastic.
dan1w
