Rear lights
Rear lights
by craigyboy » Wed Jan 23, 2013 8:13 pm
The rear side lights are not working and the indicator lamp is
illuminating on the dash board.Ive checked the fuses and lamps
and they are all ok.Does the lighting go through the ECU? Anyone
any ideas?
Thanks
Re: Rear lights
by Mark1 » Wed Jan 23, 2013 8:43 pm
Bad earth?
Club Treasurer
Club Treasurer
Re: Rear lights
by Fraz » Wed Jan 23, 2013 8:52 pm
are you getting a live at the rear?
and no the circuit goes (in a simple way ) fuesd feed to light switch out put from switch to lights
it should not be going through the ENGINE CONTROL UNIT ...there is no Body control unit as in newer cars
I would start at the switch check that your getting the feed there and its working by switching a live output, it then should go to the check control unit and then to lights
the wires run up the N/S to the rear for both lights
Re: Rear lights
by v6 steve » Wed Jan 23, 2013 9:01 pm
earth or switch
Re: Rear lights
by Fraz » Wed Jan 23, 2013 9:01 pm
do the front side lights work ??? do all the other rear lights work fog light and reverse
Re: Rear lights
by craigyboy » Wed Jan 23, 2013 9:23 pm
Yes the front and the rest of the rear lights work
Re: Rear lights
by craigyboy » Wed Jan 23, 2013 9:45 pm
Yes i'm getting 12v at the fuses
Re: Rear lights
by Fraz » Wed Jan 23, 2013 10:14 pm
so the front work ...but are they standard lights or aftermarket ones ...and if so are they using the standard front side light circuit ?
are you getting 12V at the rear lights?
are you getting 12V from the light switch ?
Re: Rear lights
by craigyboy » Wed Jan 23, 2013 11:24 pm
Yes they are standard rear lights.They were working
before the problem with the ECU
Re: Rear lights
by Fraz » Wed Jan 23, 2013 11:26 pm
Front lights are they standard ?
Re: Rear lights
by Fraz » Wed Jan 23, 2013 11:38 pm
you must have pulled a connector off some place behind the dash ...the ECU has nothing what so ever to do with the lights
Re: Rear lights
by craigyboy » Thu Jan 24, 2013 8:06 pm
Cheers for the help guys,got it fixed.It was the connections behind
the switch.Must have bumped it at the weekend moving the loom.
