Rev counter not working.
by Rob-se9 » Sat Mar 19, 2011 1:18 pm
I finally managed to get the engine all up and running perfectly without any problems. I let the engine run for awhile checking everything and then turned it off. I left it for 15-20 minutes and then started the engine again. I noticed the rev counter was reading just above 800revs before the needle dropped to the bottom. I also noticed that the oil pressure gauge is off the scale when it was reading fine the first time i started the engine. Ive just checked all earth points, connectors and for broken or shorting out wires and i can not see any. Has anybody else had this problem?
Re: Rev counter not working.
by LE16 » Sat Mar 26, 2011 11:17 pm
Nope but if you have gone through everything then maybe it's time to test the clocks?
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
