'97 V6 Engine Electornics Connectors
by beastboy » Thu Oct 29, 2009 6:31 am
Just fitted new belts and Omega cams, but has taken months to complete. Is there a diagram anywhere which shows what colour plug goes where on the Engine. Are they strictly colour coded?, or should a red plug go in a black socket for instance.?
Tom
beastboy
Re: '97 V6 Engine Electornics Connectors
by Fraz » Thu Oct 29, 2009 2:52 pm
don't think there is any diagram, but most will be obvious were they go to ...any your not sure off take a picture and I am sure someone will tell you
and yes the red plug will go to a black connector ..thats the knock sensor
by v6 steve » Thu Oct 29, 2009 10:15 pm
most will fall into the right place and only fit the right connection
by beastboy » Sat Oct 31, 2009 2:53 am
Cheers for replies. should complete next week. Will take photos if stuck.
Tom
beastboy
by beastboy » Wed Nov 04, 2009 11:55 am
Fraz, thanks,
yes I did have a red plug and black conn', for both the front and rear banks.
But also I have a black plug on the loom on the RH side of the eng' which I am assuning goes to the grey socket on the valve under the top part of the plenum chamber. Is this correct?.
Tom
beastboy
by Fraz » Wed Nov 04, 2009 2:57 pm
A picture would be far better ..atke a few from a few angles
by beastboy » Wed Nov 11, 2009 3:09 pm
Sorry for delay. Here are pics.
beastboy
by beastboy » Wed Nov 11, 2009 3:15 pm
Re previous 'reply', no explanations coz its the first time Ive done pictures and Im struggling.
One pic' shows the 2 red to black knock sensors on the offside of the enine, one for each bank. Correct?.
second pic shows black plug which comes out of loom on nearside of the engine.
third pic' shows grey socket which is on valve under plenum. Black plug in previous pic' does reach and is correct size. Is that the right place.
beastboy
by v6man54deg » Fri Nov 27, 2009 6:17 pm
yes mate thats your idle air control - black plug goes to it - two red plugs are correct - anti knock sensors
www.v6 technicians.co.uk
beastboy wrote:Re previous 'reply', no explanations coz its the first time Ive done pictures and Im struggling.
v6man54deg
by vectrasimonsri » Fri Nov 27, 2009 6:40 pm
as above he is right
vectrasimonsri
by beastboy » Mon Dec 07, 2009 8:09 pm
Thanks for replies, sorry for delay, have been in Spain. Have got it all together, other then a duff coil pack, she runs nice n smooth. Thanks again.
Tom
beastboy
by tazz666 » Mon Dec 07, 2009 8:34 pm
i have a coil pack spare if your interested, :D
